I have a 2003 Tohatsu MD40B and when the battery is hooked up I can’t get the tilt and trim to work at all. Worked fine until I tried to switch batteries when it was running on low voltage. I have checked the fuse panel under the console and just went ahead and replaced them. Is there another inline fuse I should expect and where is the main on on the motor? Also any direction towards where the solenoid is at would be helpful as that’s next up on the list.
