Hi
I have a Mercury 1985 (Brown band) 75 HP outboard. It's a 2 stroke but with 4 cylinders.
The engine was starting and idling fine, but when put into gear would cut out. General consensus is this is fuel/carburettor related, any thoughts on that point welcomed.
Now, however, it won't turn over. I put a spanner on the flywheel nut and it turns counter clockwise ok (i.e. when looking down on the flywheel), but will only return to it's starting point when turned clockwise, i.e. back to the point I started and then is stuck.
I can't start the engine at the moment as a result, it simply sticks at that point.
Any thoughts/advice welcome.
NB: I've tried taking out the spark plugs, still doesn't turn. I've put WD40 into each cyliner (whilst plugs are out) and still doesn't turn?
Arekid
Arekid
