"Recently managed to get the p
"Recently managed to get the pump on my 25 hp 3 cylinder loop charged Johnson going as I replaced with a new pump kit. Its all installed and the lower unit attached and works like a pearl. Problem is, the gears seem not to line up. In neutral its ok; then in forward ok, but when go back to neutral it is still in fwd gear. Will go back to neutral when going beyond the neutral mark and just into the reverse gear zone. Do I have major problems? I think if I could somehow adjust the positioning of the 'gear arm' then all will be solved. Your help is much appreciated and I thank you in advance. Cheers, Tas."
