Quick Silver
Hi Guys I need some help please and thanks
I have a 2007 4.3L Alpha One Mercruiser Engine that is hesitating a bit on me. The motor runs fine at start up and idles at 800 rpm no problem. When I get the motor out on the lake it hesitates ~10% at mid and high throttle. When i'm driving it slows down 10% and eventually speeds back up 10% to the original 100%. The motor gives you the feeling that you have water in the gas but I have used only high test gasoline in the motor and I know that is not the case. I sprayed some Seafoam through the carb and ran the motor at 1800 rpm to see if i could clean out the top end but this did nothing to solve the hesitation and surge back up problem. I'm not sure where to diagnose next? Could it be I need a new fuel filter maybe, or maybe distributor cap, or new wires, ignition coil, fuel pump, spark plugs not sure where to look next? Any ideas would be much appreciated. Kind Regards.
