Help please 1995 150 efi
S
shawn jacob
Guest
engine runs perfect over 2000
engine runs perfect over 2000 below 2000 runs rich loads up #5 . you can hear and feel 1 cyl flooding then lighting have good spark good comp new switch box new trigger all new gaskets and reeds engine is running to temp fuel pressure 36psi throught rpm range. fuel pump reads low mode and 2-2.75 amp draw no codes all sensors pass. no leaks in injector rail or injectors. pressure regulator flows freely idle timmming good tps set @22-26 idle rpm 750 HELPPPP!
