I have a 1982 Mariner 25 hp ser # 695-311253 that I had to replace the impeller and the pump housing on! I did this today and started the motor and there was still no water comming out of the tell tale! I took everything apart and checked it all again and the only problem that I can find is that one of the 3 bolts that hold the housing in place will not tighten! I was talking to a boat shop and told them what was going on and they said that the bolt not holding it tight is letting the housing lift and loosing the water there instead of pumping it up! Does this sound right? I am going for diffrent stainless steel bolts today! Just for the record if I put water directly in the water line it comes out of the tell tale nice and stron so I know there is no blockage and the lower end is clean also!
