Brian Springstead
I have purchased a 1984 31 tiara with twin 350 crusaders. The engines run fine after warm up and start well. I know I need to rebuild the carbs because they are running rich (gas on water at start up and I have fouled plugs after about 20 hours) MY question is , should I just replace these carbs with edelbrocks and be done with it. I don't trust myself to rebuild the old carbs myself so I would be paying to have soemone else rebuild them for me and do adjustments. I can replace the carbs myself and work with the edelbrocks. It looks like I can get new carbs for about $380 a piece after a quick serach. If I do which of the two marine carbs should I get? The money doesn't bother me too much, I want a boat that runs well. Also does this engine need solid core plug wires? It does not have them now, and if so where to get a set or should I make them? I read a thread on fuel line compatability between the old carbs and the new edelbrocks, any suggestions on which lines to use. Right now it has the alum fuel line to the carb but after the fuel filter they have cut the line and put in a section of rubber hose and then continues the alum to the carb so I have an easy spot to replace the alum section to the new carb with a good flex fuel line. Any ideas.
