P
paul pickhaver
Guest
" hi,
i have an 1982 yamaha 5
" hi,
i have an 1982 yamaha 50ce outboard which wont start!
it has a spark,turns over but seems to flood on the lower cylinder all the time, i have removed carbs checked and cleaned the float valves,checked floats for leaks e.t.c.
it will spin over for about 20 sec's then kick back and backfire then spin for another few sec's and backfire again, could it be a timing problem?
any tips on making sure i have the throttle/advance linkage set correctly?
also will this motor run without the rectifier fitted and working? this was faulty so i have disconnected it pending the arrival of a replacement unit.
many thanks in advance
paul "
" hi,
paul "
