UberPrutser
Hello all,
I've traded a small polyester tub for some cases of beer
It has a 15 hp Evinrude engine and it even runs. (Been standing still for at least 4 years)
But before I dive into the Dutch lakes I want to do a little checkup/tuneup/maintenance.
The first thing on my to do list it to find out what model engine I've got. This will make sourcing parts and finding info much easier.
So far all I know is that it's a 15 hp two cylinder two stroke engine and I think it has an electronic ignition.
Unfortunately some previous owner removed the serial numbers for some odd reason.
I'm posting a few pictures below, hopefully someone will be able to identify this engine from these images.
As you can see from the images someone has done a bit of creative tinkering.
It looks like they made a mechanical stop to keep the engine from over revving because of the governor spring mount broke out of the engine housing.
Correct my if I'm wrong since my only experience with 2 stoke engines is my lawnmower.
Also, note the creative usage of garden hose .
After identifying the engine I want to compile a list of all things that need to be serviced.
Within reason off course. I've bought it for a few cases of beer I'm not going to rebuild the block.
So far I've come up with the following: Get some new spark plugs. Replace the fuel filter and air filter.
Any help and tips extending my to do list and identifying this old lump would be much appreciated.
Thanks in advance.
Wobbe
ps. I will post more pictures if needed.
Thanks in advance.
Wobbe
