dwstoddard
Hello, I purchased this boat and I was looking at the trim and tilt motor. I see what I believe is the wire for the anode however I am not sure where it should attach. The length cable and diameter of the lug suggests that it should attach to the pressed in pin located just above it however I want to make sure before I tried to remove then replace the pin at point "A". I would have expected it to be mounted on a screw connection so it would be easy to replace however I do not see any screw location in the area. Is point "A" the correct location or should I get a longer cable and attach it to the screw mounting at point "B"? Thanks!
