J
Jeff Yoscovits
Guest
" I need help getting this Joh
" I need help getting this Johnson 115 to run properly. #4 cylinder is missing. Carbs have been rebuilt, dist cap and rotor replaced, corroded, shorted wires to the cd sensor replaced from connector to dist, repaired from pulse pack to connector. All wiring checked and rechecked. Fuel pump replaced w/ part # 438557 (listing called for 438559, dealer said 438557 should work). Have good, clean properly mixed fuel. Compression is 135 in all cyls. Dealer tested spark w/ spark tester and stated it was OK. I just bought this motor. prior owner states it ran fine when last used July 2000. Could the shoryed sensor wires have damaged the pulse pack and affect only # 4 cyl? It seems to be an ignition problem since I sprayed fuel mix into carb w/ no results. I'm at a total loss right now and looking at your replies to other posts, it seems you've seen quite a bit of strange problems. Any help would be appreciated. Thanks,Jeff Yoscovits. "
