Please see links below to pictures:
https://drive.google.com/open?id=0B8NiQG9bR6z6MmRBTU9BVnFDRTgyekxHc2U0SE9pcGVKUEow
https://drive.google.com/open?id=0B8NiQG9bR6z6SDVqUEt3QzUwOHl5T2txbUE1dnhPWHNGT1Jr
I have a 50 HP Johnson that has fouled plugs since I got it second, or third hand. I checked the timing at idle and it was off the charts. I had to shorted the control linkage considerably - ~1-1/2" long now - to get idle at the correct location. I am having trouble getting the idle mix on carbs to work correctly. I am thinking maybe this is the culprit? I have sprayed carb cleaner around the throttle plate post and there is an air leak there, but from what Ive read that is fairly common. I have to back the idle screws on the carb out 4 turns just to get it to start and run with a miss... any idea what this port is?
