psycopanther
new to the whole boat thing. picked up a 85 sunbird with the aq125/270 ( i think!) motor for super cheap. hull is in great shape, motor has not ran in 2+ years from what i understand.
put new timing belt on per instructions in manual, i am PRETTY sure that i have its base timing set. problem is i am not gettting spark at all. So, i went and boat a ignition coil from autozone for a 85 volvo with a 2.3L engine. it states on the coil that it needs a external resistor. I cannot read any numbers on the original coil I have and not sure if it needed the resistor or not.
can anyone describe where the external resistor would be if i had one? is it a little round metal thing on the side of the distributor? i think i have one of them.
also, i no NOTHING about a points system. would mine be the points of electronic ignition?
thanks! oh yea, and first post !
