Help identify gear fluid leak. [Alpha One, Gen 2]
Mark22
Hello folks, please help if you can offer advice. A small leak has developed right at the end of the red pencil as seen in the photo. Whats you're diagnosis and what will it take to fix? how bad if I continue to use as is.
this is from my 1992 SeaRay 5.7 lt V8. Outdrive is Mercruiser Alpha One, Gen 2
thanks kghost for sharing that other feed. good info in there!! that leak looks to be the same as mine. I'm afraid I won't be able to dissaseble the whole LU thing and get it back together correctly. what do you suppose a shop would charge me for this sort of repair?
Did you ever figure out where the leak was coming from? Im having the same issue.
