Hello. I have a Tohatsu 2.5 hp 2 stroke that I use to power a small sailboat. When I move the throttle lever past 40-50 percent the engine begins to lose power and shuts down after 10 seconds or so. I can keep the engine running if I use the choke - at about 50 percent closed. At WOT with the choke at roughly 50 percent on the engine will run at about 85 percent of max rpm.
I have completely disassembled the carburator - twice. All clean inside. Float floats, the little valve that controls fuel flow to the bowl clean and moves easily in its slot. Blew out all of the passages in the carb body I could find - all clean and clear.
Fuel tank outlet, shut off valve, hose to carb checked - blew out - all clean and clear.
Spark plug had a little bit of oily residue on it. I cleaned, touched up the edges with a small file and checked gap - all ok.
Amazing thing is that it ran when I put it back together, but no improvement in the situation I describe above.
I would appreciate any thoughts on what I can try next.
Thanks!
George
Thanks!
George
