Looking for input to a challenge
I have a 1990 20' Searay w/4.3L v6 mercruiser Alpha One 175 hp w 2BBL carb - about 700 hours.
Running I have an intermittent power loss. The boat still gets up on a plane and runs at 30+ mph, but something is not quite right. Doesn't pop a wakeboarder up the same way, tops at 35 mph verus 43, needs an extra 500 rpm+ to stay at 21 mph, and so on. So still runs but doesn't have the same power. Sometimes the power loss cycles on and off every few seconds and sometimes it just stays lower for 3-4 minutes.
I drained the fuel tank and replaced it all thinking it might be bad gas or some water. I have a racor fuel filter/water separator too. I checked the carb for debris in the float bowl and/or the float not closing but that was all ok.
I have new plugs in (the old ones didn't look too bad - no obvious clues).
The oil is a overfilled, which I will remedy regardless (changed when the boat was not level - oops). Based on the plugs I don't think it is oil fouling though.
I have not done a compression check but with the intermittent nature would not expect to start there.
As it is intermittent I cannot tell if it is heat related but it *may be* worse once warmed up (or maybe I am just running the boat more once it is warmed up and so notice it more).
So, the question is: the diagnostic path recommened and what tests I might be able to do versus rebuilding/swapping components and see when it improves - as the boat is not in the water, individual test runs take a while! Also because it is intermittent I expect some of the obvious tests like (say) 'does the coil spark' may not help.
So fuel/carb or electrical first, and what path through each?
Any recommendations? Your input is welcome!
