Help cooling a 67 merc 500 50 hp serial# 2167927
billgabbert1
hello this is my first post on
hello this is my first post on here. i just got a 67 mercury 500 50hp outboard motor the serial number is 2167927 thunderbolt ignition. when i put it in the water i noticed that there wasn't water coming out of pee hole so i shut it off and took lower unit off and ordered a new water pump.(still waiting for it) the question that i have i think that i can see the hole were the pee tube is supposed to drain out but no tube and can't figure out were it is supposed to go. can anyone tell me ware the tube come off the motor. if it does??? please help i dont want to run motor without knowing that it is ok.
i looked and could see two lin
i looked and could see two lines that were looped from the top of the motor to the bottom of the motor. the big hose smelled like fuel when i took it off the little one smelled like??? i blew through the tube and could here air sounds like coming out of the exhaust. i have the lower unit off now when i get home from work i will run some wire down it i will post a pic of me pointing at the line any comments helps thanks
ok so i looked on the motor fo
ok so i looked on the motor for a cooling port i found one on the top of the motor by the flywheel. took it out and fabed up the hose to hook to the water tube on the lower unit(it's still off) water came out is this the right port? will it work or will i be interupting the water flow to something else.
"Run it, if it had a pee hose
"Run it, if it had a pee hose and it became disconnected, you will see the water coming out of the connection point. As stated there should be a small plastic fitting. Pee hoses are small hoses about 3/16", nowhere near the size of the hoses you have pictures of. Since you are in the area of the fuel pumps, my guess is the hose that smelled like fuel was a fuel line.
The other line I believe is the vent / bypass / transfer line from the water jacket and the smell is exhausted water that runs through that hose.
Sorry but I just can't recall if the model had a tell tale water outlet. It may just expel the water through the exhaust port.
Take care that the shift linkage is aligned while installing the lower. It is easy to miss-align.
Good luck."
