C
Capt Fuzzy Francois
Guest
"I have a 130 with very low ho
"I have a 130 with very low hours. It has been retrofitted to new style VST Tank assy due to recall. It starts up perfectly after }setting at dock and runs perfectly until I stop and Idle around looking to find bait. After iddiling it won't get on plane, it spits and sputters and backfires through the intake. If I turn it off and let it sit around 20 minutes it will run great again until I back it down and idle and then same problem. }It sounds like it does not have enough fuel. I have removed the onboard fuel system and hooked a 6 gallon tank new bulb and hose directly to low pressure pump all connections clamped with new clamps no gromet where it comes through lower cowling.No change. I have removed the VST tank and inspected it it was very clean, I cleaned it anyway and checked for proper float valve setting and also proper opreation. I have replaced the high pressure fuel pump and filter, no change. I claimed another high pressure pump on warranty and replaced it again, no change. I have checked all hoses in fuel system all are good. I have replaced o ring where fuel hose enters VST assy. I have installed new fuel regulator valve. I have also noticed even when the boat is running good that if I hit a big wave the motor will cut out for a split second. Also motor is mounted on jack plate when I take off if I trim motor to far down it will spit and sputter, trim up a bit and problem disapears. Could float level be to low and I am sucking air when I hit a wave? Is there an oil level switch that could be malfunctioning? Please} help !!!!!!!!!!!!"
