Hey guys!
I'm out of ideas and hoping somebody on here can lend me their brain for a bit. I've got a AQ131D Volvo that I just can't get started. I've been doing some work on it recently. First the U-Joint bellows needed to be replaced, then the impeller. While I was doing all this I changed the oil and filters for both the engine and sterndrive.
After all this was done I tried starting it up and just as it seemed the engine was gonna start up it would backfire (extremely loudly) and die. I looked things over and decided to replace the spark wires as they were very old and one had some burned insulation. While I was at it I replaced the points. This time when I started it up there was nothing. The engine turns over but it seems like it's getting no fire...not a rumble or backfire or anything.
I've tested and the new wires have a strong spark. I reset the points as best I could. I cleaned up the carb and made sure the jets aren't clogged. I've hooked up a external tank with fresh fuel, even tried spraying some starter fluid directly into the carb.
I'm out of ideas....Any of you marine geniuses have a fix for me? Or perhaps you at least can point me in the direction of what to test next?
