Help 81 johnson 50 hp still on 1 cylinder
blue_blade
"Ireplaced coils , plugs and w
"Ireplaced coils , plugs and wires still running only on bottom cylinder . Before i order a power pack is there anything else i could check ? Can the top carb starving the top cylinder for gas ?"
"If you have proper compressio
"If you have proper compression and spark on both cylinders, to check the carb, have the engine running and stick two fingers into the carburetor throat (acting as a manual choke). If the top cyl starts firing, the carb is at fault. If not, the powerpack is most likely flawed.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
