lastcast24
Need help trying to find out what the length of the shift rod is for a 1985 Johnson 140.
On the J140TLCDC there is a hole at the top of the shift rod (part number 0333006). The rod comes from the gear case to just inside the the base of the lower engine cover. It has a 45 degree bend at the top (about 45 so please do not measure) this bend is towards the boat and is at the back of the engine under the intake manifold of the carbs. This is where it connects to the lever that controls the shift rod (moves it up and down with the movement of the remote, pushed forward to engage the 2:1 ratio forward gear l or pulled back to go astern). When I put all back together and the gear case was aligned correctly, I noticed the hole at the top of the shift rod did not align with the holes in the control connection to slip the pin through. I knew that forcing the alignment would mean the gear would be engaged which I proved by doing just that, hence I lost neutral (at the mid point of the remote lever) stripped it down again and compensated for the rod being too low.
I am not an expert so if I use very basic language to explain, my apologies and as you have 11808 posts somehow I think you knew exactly what I was referring too. You are correct the rod was too far down however I had measured the distance as per the manual and it did not line up. I was only trying to say that if you have only dropped the gear casing then the control arm has not moved it is the shift rod that is in the wrong position and this can easily be adjusted to align (I gave the long winded answer just to prove I had done the job)![]()
What was the final measurement? I am having an issue with mine too. With the shift lever in reverse and the transmission in foward I can get the linkage connected but it doesnt move. seems about 1/2" short.
