firemanlowden
Have a 1975 mercruser 165 cran
Have a 1975 mercruser 165 cranking hard. I took out the plugs and lubed the cylnders with oil and let sit for 24 hours. loosend it up very little still cranks hard without plugs in. If plugs are in when it hits compression stroke it stops. I am useing a car battery that has a full charge. I even used a battery charger hooked up to it at the same time. I know it has sat for 2 years without beeing started. and was properly drained. How do I fix this problem. is there a differance in useing a car baterry vs a marine battery?
