HELP 155HP evinrude wonbt stay running
J
Jonny Peters
Guest
"I have a 1988 155HP evinrude
"I have a 1988 155HP evinrude that starts quickly, runs for a few minutes (as long as I play with the choke at the ignition switch), then dies and starts right back up again. Does anybody have any ideas as to what might be causing this? Also, while looking at the carburetors (from inside the boat) there is something that looks like a solenoid on the left hand side of the carburetors with a red switch on it. Does anyone know what this might be? Any ideas will help. Thanks!!!!!"
"That item has replace the tra
"That item has replace the traditional choke flappers.When you push the key in, it opens and sprays fuel into the intake manifold."
The red knob allows one to ope
The red knob allows one to operate the primer manually. Dead battery / strong arm / manual prime and the motor can be started with a rope.
"Your explanation of the probl
"Your explanation of the problem indicates that the carburetors are fouled. Remove, clean, and rebuilt them using complete carburetor kits.
(Fuel Primer Solenoid Function)
(J. Reeves)
The RED lever...... The normal operating/running position is to have that red lever positioned over top of the solenoid and aimed at the other end of the solenoid, gently turned to its stop. This is the normal/automatic mode position. Pushing the key in opens the valve within the solenoid allowing fuel to pass thru it in order to prime and start the engine. Looking upon this solenoid as a electric choke results in a better understanding of it.
Having that red lever turned in the opposite direction, facing away from the solenoid, allows fuel to flow thru it to the crankcase area. One would only turn the red lever to this position in a case where the battery might go dead and the engine had to be started via the rope pull method. Look upon putting the red lever in this position as moving a choke lever on a choke equipped engine to the full closed position. Either one would supply fuel to the crankcase/engine for starting purposes BUT if left in that position while running would flood the engine.
The later model primer solenoids are equipped with a schrader valve, used for attaching a pressurized can of fogging oil etc, available at your local dealership with complete instructions.
Pumping the fuel primer bulb up hard fills the carburetor float chambers of course, but that process also applies fuel pressure to the primer solenoid.
The two small hoses leading from the primer solenoid branch off via tees to each fuel manifold section that would feed fuel to the individual cylinders.
Pushing the key in activates the primer solenoid to allow fuel to flow thru it to the intake manifold passageways. Cranking the engine over causes the fuel pump to engage which in turn sends fuel pulses to the primer solenoid via the 3/8" fuel hose.
Some engines incorporates the "Fast Start" feature which automatically advances the spark electronically so no advance of the throttle is required for starting.
Engines that do not have the "Fast Start" feature will be required to have the throttle advanced slightly.
Starting procedure: pump fuel bulb up hard, crank engine and push the key in at the same time. When the engine fires/starts, release the key so that it falls back to the run position.
Bottom line..... Look upon the primer solenoid as an electric choke.
When time permits, visit my store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
Thank you so much... I put the
Thank you so much... I put the red knob back in the right place and cleaned the carbs... the motor runs like a champ now. Thanks again!!!!!
