I am working on a 1982 40 hp merc . the intake manifold was cracked so i repaired it, clean every thing up put gas and power to it, vroom wright off the bat it started up . good strong flow through the tattel tail every thing seemed to be fine . untill i looked at the water stream and it was steaming . i shut down the moter asap . it was to hot to touch . I do believe something is wrong . to tell you the truth Im not sure were to go from here . any sugestions . oh it only took about 1.5 min for the steam to acure . its in a 55 gallon steel drum and i saw no exsaust bubbles from the drum of water it is in .
