Heat Exchanger Cap
briang0
My heat exchanger cap is very
My heat exchanger cap is very rusty I can't see any markings on how many lbs it is. I have a 280hp Crusader 409 chevy BB. How can I tell what the replacement cap should be. The engine is 1/2 fresh water cooled.
"you can test it with a radiat
"you can test it with a radiator pressure tester and see the pressure when the spring gives. if you don't have one, take it to a radiator shop that does.
if marked, they are usually stamped on top of the ear - may need to wire brush it. size is most likely a standard "a" sized cap."
"Rick had posted a note on the
"Rick had posted a note on these caps a few months back an mentioned that there was a change for the new pressure cap....If I am not mistaken, use the newer cap"
