sirs i have a johnson 70 horse
sirs i have a johnson 70 horse outboard j70elcnb 1982 iam about to replace head gasket but need the tight sequence and torque specs if possible i found traces of moisture in lower cylinder and feel it is causing an issue on my planing out it wont plane very low power almost strictly idle and rough at that carbs are rebuilt to specs compression is good slight varience and sprk is good to plugs found upper and middle cylinder plugs look fine lower plugs looks totally different can i get help with the specs thanks
