Canadianwalleye
Took out the boat a few days ago. Took out the new spark plugs to see if they are still being fouled ( old owner had wrong spark plugs in). No fouling but when I took out the bottom spark plug on each side, water came out. Was not much but pretty sure it was water. Bubbly clear fast moving. After then little bit of water came out then oil came out. Not lots. What would cause water too be in the cylinder? I’m hoping it’s just a head gasket leak in which the water from the water jacket is leaking into the cylinder... both bottom cylinders had water (two second glug glug worth)
those who have been following along know some of what I have done so far (not much hahahha). Original problem was sputter at low idle and then fuel everywhere upon launching (after a few days of use). I cleaned the carbs (found rubber in the float pin seat and more in the low speeed orifice). Replaced the fuel lines leading up too the carbs ( old ). Replaced spark plugs ( wrong ones were in it). Put everything back together (and apart and back together X5). No more leaks! But still has a slight bog/caugh at low idle. Noticed the engine would get pretty hot too the touch so I assume the thermostat is messed up. Will be changing it soon. And then the water coming from plug holes. I think I should shift my focus too this problem as water in cylinders is a bad thing! What should I do to troubleshoot the cause? Do you think the engine block cracked?? How do I check this without taking it all apart? Is it likely just a head gasket?!?
Its a 78 115hp Evinrude.
Thanks everyone!
Thanks everyone!
