RMSherman3
I have a 1996 Mainship powered by two Marine power 454 Chevys with throttle body injection. I recently had the heads pulled to complete a valve job and I’m fairly certain my mechanic installed the wrong head gaskets. I’m wondering if what’s installed will work or if they should be replaced and if so why?
The engine rear block #0114182
The engine front block #106195XY
Valve cover
Model S454S-40SBR
The head gasket set that were installed
Fel-pro #8523 PT 1 AF 18153
For a 454 7.4L 1980-1995
All the bolt, oil, and coolant holes match up, however, the gasket doesn’t cover the top of the block between the cylinder's. It comes to the edge of the cylinder on one side and up to 3/8” back from the edge of the opposite cylinder. Any thoughts on this will be greatly appreciated!
Valve cover
Model S454S-40SBR
