Having problems with the ignition on a johnson 55HP motor
kwh
"hope some one can answer this
"hope some one can answer this, This motor was starting fine, Then the starter went out so i just re-placed it. Now, after i get it started, it won't shut off. Is this problem the key switch? or something else i should look at?"
"have u been messing w/the key
"have u been messing w/the key switch,if so u have mis located a blk,..or a blk/yellow wire.use an ohmmeter,to ck continuity,on the blk/yellow wire at pack....disc fr pack,hook one ohm lead to blk yell wire,other lead to block,w/key OFF ,u should have cont...w/key ON,IT SHOULD BE OPEN."
"Thx again jwb, I checked cont
"Thx again jwb, I checked continuity at the pack with ohm meter, key off, and there's no continuity. Does that point towards the ignition switch?"
"hey jwb, wanna thank you for
"hey jwb, wanna thank you for your help found the black/yellow wire broken where it leaves the motor thx"
