H. I. McDunnough
Has anyone had this happen before?
I was gone for a week. When I came home, there was a small spot of gear lube on the concrete below my outboard. I traced the oil up the back of the skeg to between the gear housing and the prop. The gear oil was just like it came out of the tube; no water had leaked in when I ran it last. I wiped it up and let it sit over night. No more came out. I took it out and ran it the next day. It ran great. I let it sit over night, and still, no more leaked out. I opened the drain screw; no water, and still the oil was perfectly clean. I opened the fill screw and drained a little off. Everything looks good. I'm pretty confident that it has stopped.
Last week we had a stretch of 100+ temps. around here. Is it possible that the oil expanded and forced it's way out the lower seals?
I change my oil in Nov. or Dec. when it is just above freezing; that's quite a difference from 107 degs. I also have never drained out the ounce of oil, that the manual tells you to, to allow for expantion. I suppose that I had better from now on ( in the back of your mind, you always think that more is better).
Has anyone been through this, and has the leak come back?
