Harmonic Balancer Bolt STUCK
cuppa
"Any one know any tricks to re
"Any one know any tricks to remove harmonic balancer bolt? These are not reverse threaded correct? Trying to break down a 2004 6.0L and The bolt is not budging, is it ok to apply heat, or will that damage the crank? Any help is appreciated.."
"Heat won't help since you
"Heat won't help since you can't get it where you need it. Lock the flywheel with a C-clamp, then get a breaker bar with a pipe on the end. It's 'normal' threads, by the way, not LH.
Jeff"
Not with mine! It's a 90
Not with mine! It's a 90 ft-lbs unit. I'd wreck all kinds of stuff with with a "real" one.
Jeff
"[b]"Buzz it off with a 1/
""Buzz it off with a 1/2" air gun."
Ayuh,......
If the Crankshaft wants to turn,.....
Pull a sparkplug,+ push a length of Rope into the cylinder to Lock the motor......"
Finally got it the other day..
Finally got it the other day.. Used a impact wrench and then finally got it with a breaked bar with pipe........ I had tried bot before but I think it kept loosening up... Thanks
