markkingscraft
"Greetings,
Thanks to all f
"Greetings,
Thanks to all for your suggestions this summer as I fought with two "rebuilds".
As of yesterday at noon I have two 318s running with enough power at idle to put them in gear. Test run coming soon - as soon as our election is over up here in the soon to be frozen north.
You may recall my idling and smoking and other questions from earlier in the summer.
Here are a couple of tips that some may find handy in the future.
Both engines and parts were rebuilt and fuel tank was new.
Although the carbs were rebuilt one required a three day soak and agitation in cleaner to clear out the idle passages. As soon as that was done it finally attained idle at Jeff's recommended settings.
The other one idles but it is rough. It will be soaked this winter.
Also involved in my idle problem were distributor weights that appeared to move freely but remained "stuck" at odd locations after high speed.
It took a $1000 timing light to figure this out (lucky for me it belongs to a mechanic friend so I didn't have a cash outlay) when he was finally able to read timing that was apparently out by about 30 degrees out even though it had been set properly.
A little WD40 and an oil bath solved this problem on both distributors.
Finally, - and I still don't know how this happened - I put 15 gallons of fuel in the tank and in the middle of figuring out all the above issues, I found three gallons of it was water.
But not until it had slowly filled both carbs and all the lines causing even more idling and running issues.
We're operating on up to 10 per cent Ethanol up here now and it is a flat tank and we had wet and humid summer - but it still seeems odd.
The good news, after dropping these babies in the first week of July I have a few minor, minor things to resolve and I will once again have a working boat - after a two year complete stripping and rebuild of a salvage boat.
Thanks everyone for all your assistance and your answers this summer at the height of my frustration. They all led me along the way.
Mark"
Thanks to all f
"Greetings,
Mark"
