Regardless of what is the cause of your problem, you should always start with troubleshooting basics........
Remove the spark plugs and check the compression. What are the psi readings of all cylinders?
With the plugs still removed, check to see if the spark jumps a 7/16" gap with a strong blue lightning like flame. Does it?
Describe your starting procedure in detail.
While watching the carburetor throat, pump the fuel primer bulb up hard to make sure the fuel isn't flowing out of the carburetor (flooding).
(Carburetor Float Setting)
(J. Reeves)
With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Recommended spark plugs are Champion QL77JC4 plugs gaped at .030 .
Let us know what you find.
