Hard starting 90 hp johnson
olive
"Motor runs well when warm, bu
"Motor runs well when warm, but is very tricky to start cold. Needs a lot of gas and many tries to start. It must be run for a while to shift and pull out."
You need to start with the bas
You need to start with the basics----First a compression check and a spark check.Spark must jump 7/16" gap at each plug.No point starting the trouble shooting anywhere else.
