Very hard to start but once it's going it restarts ok IF not too much time goes by.it gets hard to start again if it sits, I was thinking it's a weak fuel pump( old motor), weak vacuum!!!) and am considering installing a 12 v fuel pump ( rather than the standard squeeze bulb) but not sure of the pressure/pump to use or if I should just wire directly to the battery with a toggle or on off switch and should I use an inline fuse ??!! Anyone have any experience doing this or info/suggestions? HELP!!! Thanks in advance!!! Ps. new bulb and hose/connections did not solve problem!!
