"When the engine has been tilt
"When the engine has been tilted awhile, after being run, it is hard starting, it sometimes takes 4 or 5 cranks, before it starts, and then sometimes after start it will stall. And then have to repeat this procedure until finally staying running. The primer ball does not always stay hard (even though some manauls says it should). Could this be the problem (primerball) or is it within the carbs. Would I be wrong in rebuilding carbs and fuel pump. Any ideas, I would appreciate any input??????"
