Hard start 1991 200hp johnson
"having trouble starting engin
"having trouble starting engine, cant tell if it is not getting any gas or if its not fireing, when i turn the engine over, it smokes out of the end of the prop, does this mean it is firing but not getting any fuel. it worked like a champ for a month or two straight, then i let it sit a week with out starting it and now it turns but will not start. any ideas, please help"
"make sure u have pumped up th
"make sure u have pumped up the primer bulb,.......make sure u are using the choke position on key,....if that does'nt wk...it's trbl sht time,which should include a ck for wtr in fuel,spark compression and fuel delivery,thru out,and an operation ck of the primer."
