doctor disaster
after it's warmed up it starts like a champ.Motor is Evinrude TE40ELESR 1990. I go through the start-up as instructed in the manual.Check fuel bulb,firm ,no air,turn key and press in for "prime",throttle about half way(tried more and less same result).Motor turns over and cranks fine,good battery.After about 20 or so tries it starts.I can then re-start shortly after with no problem.Last time it acted the same only after it started,it would stall when put in gear.Took about 10 tries.I don't want to keep beating up my starter,this shoud start much easier.The Prime/boost seems to work fine because when it does start and the idle slows,I can push the key in and hear it rev up.Some things I know,Fuel filter has not changed(the Mechanic at a local shop said it didn't have one)well it does.Thats an EZ so I just may do it anyway.Also last time I filled the gas tank I noticed the cap seal showed signs of age(cracks).I would think this would affect its running too but that's why I'm asking here.I think this is an easy fix.I just need to know where to start.I have noticed when it starts it's smokey,but figure that's just loaded oil burning off.When running no smoke.I put new plugs in this year.The oil injection works fine.An annoyance,that may be signaling a potential problem?Thanks for the help.
