Capt. Lyman
I have a Gray Marine Engine in my 1965 Lyman - a CH175 that I've just replaced the port side head which was cracked. Also replaced thermostats and relief valves in both heads and a new water pump impeller. The starboard side of the engine runs at the proper temperature with 140 degree thermostats utilizing an infrared temperature gun. The port side where the head was replaced runs hot. Replaced head was machined and a valve job was performed and new valve seals installed. Can't understand why temperature is different on one side of the block than the other. Water flows through both exhaust pipes. Any ideas on why this is happening, I'm stumped?
