shagbert44
"Hello again everyone I have a
"Hello again everyone I have a puzzleing question, can the ground strap that goes from the starter to a ground post all of a sudden not be a good ground spot anymore? Reason everything worked great all season as it was, starter was acting up so I had it rebuilt guy said the brushes were very bad anyway I hooked everything back up the way it was and still the bendex would spin but not jump and I could here the starter working but not jumping to engage the flywheel. I then took the strap off where it was grounded to the starter clamp ring and ground that direct to the battery with jumper cables turned the key and everything worked like a charm. So why wold this ground position be ok for so long then all of a sudden not work anymore? ALso can I run a ground line from the top of the starter to the battery direct or should it be grounded to the engine somewhere? Thanks, Ryan"
