Great pertronix broken
tobaz
i was installing new pertronix
i was installing new pertronix to my 130d/280 today and notice that the magnet sleeve was to high for the rotor to fit (to high) so i put more presure on magnet wouldnt go down so i got a block of wood and taped it some then some more it moved down then but it brokethe magnet sleeve. my question is does any one know if i voided the warranty? part #2842
"I also had problems getting m
"I also had problems getting my sleeve all the way down but luckily I was able to do so without it breaking (I applied pressure using both my thumbs). Your best bet I would think would be to call Petronix and explain to them what happened, and I'd guess they would be happy to send you a replacement sleeve. There has been some previous discussion on this board about this and from what I recall someone metioned slightly filing it down and a mention of applying some light lubricant to it might help. You might try a search for "Pertronix". Once you get your Pertronix installed, you will love it! Good luck."
"thanks bob yes i called auto
"thanks bob yes i called auto parts store and i brought it in he said n/p
will have a new one on tuesday.
"Glad to see another confirmat
"Glad to see another confirmation of Pertronix's great customer service.
I am 100% convinced that you will love your Pertronix kit once you have it installed and tested.
"I had problems installing min
"I had problems installing mine on the rotor cam too. BUT!!!!!! I used emery cloth to get the rust off the rotor cam. you have to be careful. it is a tight fit....I mean tight.
Good for you that they r gonna warrantee it.
Afriend of mine did the same as you and he had to pay to replace it. Good job. Next time you should try a little emery, and grease. it is tight."
