"Trust me I read and search a
"Trust me I read and search a lot. I have read about how you fill the cap when I was searching but like I said it doesn't put much or any grease in when I do this. The reason I want to put lots in is because of the water leaking problem, clearly a lot of the grease was washed out. I am using this boat one more season than I will buy a mastercraft or moomba direct drive wakeboard boat, but still, I would like to keep it up to shape.
I rebuilt the whole boat, new stringers, new floors, rewired everything. My problems have been limited to blowing bellows, clearly I didn't realize that the outdrive could not be up at all when driving in shallow waters, overheating, which turned out to be a fluke where a piece of the strainer housing broke, allowing water to flush straight through without entering into the exchanger. That was what I mainly posted on this site about, and as you can see, it is something rather complicated to track down. I did all the obvious without asking questions on here, when the obvious didn't work I asked to see if I was indeed checking things correctly which I was.
The last problem I am having is ignition where it cut out suddenly, once again I did all the checks on the water determined it was an ignition problem, determined the coil was fine, and that left the electronic ignition. Respectfully, I don't see how that amounts to neglect as you otherwise suggested in another post, or so many problems. I could tear down an engine and rebuild it easy, I could re-wire or re-design any electrical without problem. I try to read through all original posts before I ever ask a question... And when asking a question I like to site what I have originally read about on here...
I don't believe I will blow the lip seal, maybe I am wrong, but snap rings hold the seals in place, and if pressure amounts enough to squeeze some grease between the bearing and seal, then the rotation of the bearing overtime will allow correction of slight deviation. Further, clearly water can intrude through that seal so I think I would rather get grease in there ASAP. I have studied mechanical engineering and with anything there are tolerances and play, any water pressure developed for any ordinary ( > 5 hours) will wash grease through tolerances and allow leakage. In essence grease is what tightens the tolerances between round surfaces."
