"I've been told that "
"I've been told that "Permatex" or similar gasket goo is the bst stuff to put on your prop shaft spline, to prevent the prop hub rusting onto the shaft. I've always used grease, and regularly removed and re-greased. What is the preferred method, and how often? Does the gasket goo work? If so, can you use it on the driveshaft splines as well? thanks in advance..."
