"I have water in the oil of a
"I have water in the oil of a 1961 Gray 188 (327 flywheel Aft) from a Lyman. I have checked the Oil Coolers (they are good). I see a crack on the outside of the block, but before I pull it out and replace/rebuild it is there anything else I should be checking? Do you guys knows what could be causing water to get in the oil?
How difficult is it to rebuild this engine?"
