GRAHAM
"Yep [img][/img]
The manual
"Yep
The manual is referring to the wire "kit".
You get a coil of wire a bunch of boots and ends.
They simply recomment a bit of RTV sealer to ensure a water tight seal where the boot/end meets the wire - so a little around wire casing close to the end and push the boot on.
Do I do that? No
I keep the entire powerhead, including the wires sprayed down with fogging oil a couple times over the season.
That's my preferred method for keeping moisture and other cooties from causing trouble."
ACTUALLY THE COIL COMES IN A B
ACTUALLY THE COIL COMES IN A BOX AND THE INSTRUCTIONS INSIDE SHOWS TO REMOVE RUBER BOOT TAKE TAPE OFF TAKE CIRAMIC ELECTRODES OUT IN 2 SECTIONDS AND SEAL AROUND ELECTRODES...
"Sorry Peter, must have misrea
"Sorry Peter, must have misread the earlier post.
What engine do you have, I can't even visualize what you are talking about.
Is this coil for a Thunderbolt 4 or CD igintion???"
"THANKS GRAHAM, THIS IS A 1986
"THANKS GRAHAM, THIS IS A 1986 75 HP OUTBOARD AND ON THE MOTOR IT IS IN A PACK OF 4 COILS. NOW I HAVE TO CHANGE ONE OF THE COILS IN THAT PACK WITH A NEW ONE, PART NUMBER 832757A. NOW IF YOU GO AND SEE THIS COIL ON http://www.miamimarina.com/miamimarine2//resources/products/4895T2.jpg"
YOU WILL SEE A RUBER COVER AT THE END IT SAYS TO REMOVE, REMOVE TAPE, TAKE APART CERAMIC LIKE ELECRODES AND PUT SEALER ON THEM..IM AFFRAID IF I TAKE APART THESE ELECTRODES WILL BRAKE
THANKS.."
"Yes, a "standard" coi
"Yes, a "standard" coil used on the Thunderbolt ignition.
I've always bought these loose, which is why I have never seen the instruction you mention that came with it - and to be honest, I probably wouldn't have read it if I did
I've never done anything more than slap these into the mount and hook up the wires..."
"THANKS I DID THAT AND IT DID
"THANKS I DID THAT AND IT DID NOT WORK SO I TOOK IT OUT TOOK THE RUBER OUT AND FOUND OUT IT WAS SMASHED TO BITS, SO I THOUGHT IT WAS BECAUSE I DID NOT SEAL IT PROB BECAUSE IT WAS DAMAGED IN SHIPPING , I HAVE ORDERED AN OTHER..BY THE WAY I FOUND MY TROUBLE BY READING THIS BLOG HAD THIS INTERMITANT PROBLEM FOR THREE YEARS AND NOW IT IS A CONSTANT FOUND THE TROUBLE AND HAD SENT TO A MERC SHOP THY NEVER DID BUT I DID.
THANKS GRAHAM SAVED ME BUYING NEW MOTOR.."
