"I am working on an 87 Force 5
"I am working on an 87 Force 50 hp A model
I am pulling the power head off of the motor leg, first time i have ever done this. my manual says to pull the flywheel and attach an item to it, and the hoist to that and pull the motor. is this how you guys do it? you let the crank carry the weight of the motor? this doesn't effect the main bearings or anything? this manual is very vague, and i don't know if the author is doing it this way because it is going to be torn down anyway, or if like in my case i am not planning on tearing down. the reason i am thinking that is because it says to take a lot of things off to pull the motor that i don't see the need to unless you are planning on doing a tear down on it. I know you guys have done a few of these so I thought i would run it by you. it would make the job a lot easier that is for sure, but i would think that supporting the crank and hanging from the crank would put two different loads on it and i don't want to find out the hard way. Thanks
I know what you are probably thinking... yes i dc have a manual, i do think that anyone who works on something without one is a fool, do i trust them? NO i have friends who write for mitchel and i wouldn't let them work on my lawn mower. my rule is the common sense rule... if in doubt, then check it out.
Thanks for the time and sharing the knowledge"
