Given a 99 Evinrude No modelSerial # tho HELP
jd4lfe
"Hey everyone...
My grandfat
"Hey everyone...
My grandfather gave me a 9.9 Evinrude he has had sitting for quite a few years now. Im tryin to figure out what model it is so I can look at parts for it. Im thinking its an early 80's- late 70's model.
Any idea what Im looking at here ? haha thanks
"i'd say early 80's...
"i'd say early 80's......see if it has a pwr pack on it...blk plastic box w/ign wires,into it and out to coils."
"I believe it does have the po
"I believe it does have the power pack. The back end, under the cowling... there is a black box with a yellow sticker on the top."
"Look at the plate on the tran
"Look at the plate on the transom bracket that is in the center of the yellow square I drew on your picture. That should have the Model # and Serial# of the motor stamped on it. If you post back the model# from the plate that will allow it to be decoded exactly.
KJ
"Hey Kevin !
Its hard to t
"Hey Kevin !
Its hard to tell in the pic, but there is NO plate there... that was the first spot I looked.
So I need another route ....
"That's a bummer. I belie
"That's a bummer. I believe those same numbers were stamped on freeze plugs on the block, but I don't know exactly where to tell you that is located.
For a long time (maybe even yet on current models?), the 9.9 and 15HP engines were cosmetically identical. There are many small lakes that have 10HP limits. A very common trick was for owners to remove any "proof" of an engine being a 15HP, putting on a 9.9HP decal (or entire hood), and sneaking past the game warden with a little bit faster boat. Obviously I can't say that's the case with your motor, but it is a bit mysterious that the ID plate is gone.
Anyway, look over the freeze plugs and the block and you might find either a serial# or Model# stamped somewhere else. Sorry I can't be of any more help.
KJ"
"The paint scheme is significa
"The paint scheme is significantly different than a 1976. If your motor looks like this (James), then it's either a 1980, has a 1980 cowl on it, or has been painted."
