"Hi folks. I can't seem t
"Hi folks. I can't seem to find my original message so here is a new one. I pulled the out drive off my 1973 165 Mercruiser. The Gimbal bearing is in deed shot. I also noticed there is a tear in the U-joint bellows. So I need to remove the gimbal ring or housing or what ever the thing is that tilts up and down and goes right and left is called. The manual is not real clear on the removal of the pins. Mine has hinge pins that have a stainless pin driven in from the back that go through the hinge pin to secure it. It looks like there are threads inside the actual hinge pin. How do these come out? Also. how does the shift cable disconnect in the housing? After getting the gimbal thing off, replacing the bellows just looks like tight knuckle banging. But any help would be appreciated.
Eric"
Eric"
