Getting ready to put the boat away a 1988 OMC 5.7 and thought I'd check the lube in the lower unit. A couple of weeks ago I was draining the lower and took a screw out that was supposed to stay had to take it to the shop so they could get the brass nut out of the exhaust. When they did this they split the lower and changed the lube, so I want to make sure its at the proper level so I don't have to worry about it in the spring. Well the dip stick is in so tight I can't get it to move. Called the shop and they said yeah they are in there tight, the mechanic has a tool he made that goes on a socket I'm sure he cut a shaft off a long screwdriver and fit it to a socket. I can't get my longest driver to the dipstick because of the swim platform he suggested to try to loosen it up with a chisel, I don't like that idea, is there any other way I can get it out, I might just take it back up there on the way to storage and have them loosen it up for me. Does it really have to be that tight? I would think not if the seal on the dipstick is good. I know it has to be tight.
