Get goin
jamie_e
"hello,
can anyone please tel
"hello,
can anyone please tell me why it feels like my
boat takes-off in second gear, and will not
pick up rpm's???? it revs great in neutral.
its a gm 4.3l w/ omc out drive
thanks in advance"
Did this just happen? When did
Did this just happen? When did you last do a tune up? What RPM do you get at WOT? WHat year is the engine/drive?
"motor is a 93 just put in boa
"motor is a 93 just put in boat, ran great befor.
new plugs, wires, gaskets and such.
it only does this under load.
could this be a timming issue?"
"Could be lots of things, timi
"Could be lots of things, timing, old gas, fuel pump pressure low, clogged filters.
What kind of RPM does it get up to?"
"ran great before in what?
do
do a compression check, check advance weights in distributor, check fuel supply and filters, check firing order of wires. evaluate ignition and fuel system visually as you check those things.
A 4.3 that's running on 3 cylinders will rev up nicely in neutral...that means nothing"
"thanks for the help guys.
go
got the fix today, took the boat out and rechecked the plug wire order, it was wrong,
swapt it up and fast it went."
